Z3c: Email Problem
Rpuzzled
New
Z3c: Email Problem
Hi,
I hope someone can help. I'm using a Z3c with the stock android email app. I am able to send and receive emails. For the past few months, however, I keep getting a notification "Could not log in" or, if I'm in the Inbox "Could not connect...check your username...etc".
The many such notifications per day are very annoying indeed.
The same thing happens whether I'm using wi-fi or mobile data. I've tried deleting the account and setting it back up, but it makes no difference.
In short, then, email works OK, but keeps giving me failure notices.
Does this sound like a problem with the phone, the app or the ISP?
Thanks in advance.
1 REPLY 1
IamNic
Hi @Rpuzzled,
maybe your email provider changed something which makes it hard for the app to access your inbox?
- Nic
