Xperia z1 compact help???
SOLVED
My xperia compact z1 is not showing a call log? Any ideas?
1 ACCEPTED SOLUTION
Accepted Solutions
Nobody-in-particular
Contributor
Hi Samaras1888, have you checked you do have the call logs hidden?  Click on phone then on the three blocks on the bottom right of your screen and you should find the option to Show call logs.
3 REPLIES 3
ClarissaW
Member
Hi Samaras1888,
Welcome to the Sony UK community :slight_smile: The best place for queries about the Xperia phones is the moblie forum, which you can find here: http://talk.sonymobile.com/
Hopefully someone will be able to help you soon!
Clarissa
Contributor
Akram11
Explorer
you can change the call settings..
