Sony Bravia Product KD-48A9
SOLVED
ian87bailey
Explorer
Home Screen is no longer displaying BBC iPlayer or ITV X
Home Screen is just showing Netflix and Amazon programs previews under the app lists
Any ideas?
It was fine this morning.
1 ACCEPTED SOLUTION
Accepted Solutions
TheMaze
Hey, did you try unplugging your TV from the mains while disconnecting all external devices for at least 2 minutes, and test?
I'd also recommend that you check if your TV software is up-to-date, along with all the preinstalled apps in the Google Play Store.
https://www.sony.co.uk/electronics/support/oled-tvs-android-a9_a9s-series/kd-48a9/software/00267389
1 REPLY 1
TheMaze
