Problem VAIO VPCF13 Automatic Brightness
Hello All...
I have formatted Windows 10 yesterday for some problem...now I've resolved but I have another problem!
The sensor of automatic brightness not work anymore,I've installed and checked already all settings but nothing yet... I've enabled in settings advsnced of brightness the auto but not work...
Who help me?
Thanks for the collaborations.
2 REPLIES 2
Sean_Mc
Hi Gabrijel_Krijn,
Welcome to the Sony Community.
I'm looking into this for you and will get back to you soon.
Cheers,
Sean Mc
Sean_Mc
Hi Gabrijel_Krijn,
If you are reverting from Windows 10, it's recommended to do full recovery using the recovery discs compatible with your VAIO so that you can get the pre-installed Windows version on the laptop and hence, no issues will be developed.
You can use the 15 digits-serial number of your VAIO to find the compatible recovery discs and buy them, or contact Sony support here to provide you with the part number of these discs.
Best wishes,
Sean Mc
