Deel jouw ervaring!
Hi! I have difficulty finding the right backpack that will fit the 17.3". There is a Belkin that looks nice but might be still slightly small. Any advice out there? I'm based in Dublin so any shop suggestions are very welcome. Thank you
Opgelost! Ga naar oplossing.
Hi NaomiDub,
check out backpacks on Amazon, there seems to be several makes that are suitable for 17/18" laptops.
Here's one for example - Targus XL Laptop Backpack
May be worth checking out some reviews on the product before partitng with your money..:smileywink:
Hi there
What type are you after? I've seen some sleeves and some larger office style bags out there.
(some quite pricey though)
There was a Vaio 'rucksack' that fitted the 17 inch AR31S fine with possibly 0.3 more
room in it but not sure.
Hi! Thanks for reply. Something comfortable to carry, I prefer the rucksack rather than bag, but ...and "informal" ,without making it too obvious what is inside, so it's not a target for thieves. The issue is really the size of the screen
Hi NaomiDub,
You trying to tout your old school backpack again Thal? :smileygrin:
OLD????
My School bag would be an antique by now...:smileylaugh:
Lol but its still in good condition though :smileygrin:
Just kidding hehe
Jumpy I think you're confused, that's an image of my new hair piece..:smileygrin:
:smileylaugh::smileylaugh::smileylaugh:
haha. In the end I went for Aspen 18.4"
http://www.amazon.co.uk/Port-Designs-Aspen-Laptop-Backpack/dp/B001R788BS/ref=pd_cp_computers_1_img
Great quality/value choice
P.S. it's not pink
