- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Changing Sms Centre number
Hi
I want to change sms centre number. because when i send a meesage it is givening error not sent
I have tryied *#*#4636#*#* but it is not showing menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In that case I suggest that you contact your operator to see if they can change the settings on the network/SIM card. Otherwise I recommend that you put in another SIM card in your phone or ordering a new one from your network provider.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am unable to change my message centre number. It required me to remove my simcard and put it into another phone, set it up and then put it back into my Z1 Compact.
It does not allow me to change it on the device.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello is there a option to set up different sms center numbers for sony xperia e dual sim?
i have problems setting it up
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
To set or change the SMS service center number of your SIM card
- From your Home screen, tap the Application screen icon.
- Find and tap Messaging.
- Tap the menu button (three vertical dots), then tap Settings.
- Tap the SIM card for which you want to change the SMS center number, then tap SMS center number and enter the desired number.
If you cannot edit the SMS center number, contact your network operator for more information.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I can process step 1,2,3. After prss Setting, i can not find tab Simcard. My Sonyex T58 (only one sim). pressing *#8#4636#*#* not express space to put sms service center.
Pls help. Tks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
1) in your dialer, enter *#*#4636#*#*
2) select phone information
3) scroll down to the end. You will find SMSC.
4) enter the desired number there and press update.
done
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Awsome tip with the key combination. saved me!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have tried the same, but after edit and try to update, it throws the error as "Update Error" . Please help
