Bluetooth Problem xperia e5
SOLVED
dokboy
Visitor
Bluetooth is constantly switching on and off randomly, about evry minut. how to solve this problem?
1 ACCEPTED SOLUTION
Accepted Solutions
Emil
Enthusiast
Hi @dokboy,
I'm sorry to hear you are experiencing this on your Xperia E5. I'd recommend that you try and reboot your device to safe mode to see if this behavior is caused by one of your downloaded app as they will be temporarily disabled in this mode.
If the same behavior persists I would recommend that you try and reset your networks settings. You can do that if you go to: Settings > Backup & reset > Network settings reset >Reset settings.
Note that this will erase all your current Wi-Fi and Bluetooth connections. It will also reset your cellular data so that you have download new Internet settings. You do that under: Settings > More > Internet settings.
Let me know how it goes!
5 REPLIES 5
Emil
Enthusiast
Hi @dokboy,
dokboy
Visitor
Hello, i was reset network settings and nothing happened, but in safe mode it was working good.
After uninstalling some of apps problem is solved.
thank you for help
Emil
Enthusiast
Hi @dokboy,
Great to hear it is working now Slightly_smiling_Face
Let me know if there is anything else i can do to help you!
dokboy
Visitor
hi,
actually there is one more problem, when i connect my xperia to car stereo it wont work, it only cut of music when i am dialling and nothing else, hadns free doesn't work Slightly_frowning_Face
if it helps i hawe Pioneer DEH-P700BT
thanks
AlexMedrano
Visitor
I can not link my Xperia with Panasonic sound equipment despite having Bluetooth on and active on both.
No puedo enlazar mi Xperia con equipo de sonido Panasonic a pesar de tener Bluetooth encendido y activo de ambos.
@AlexMedrano
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
