Have a burning question you need answered sharpish but your hands are full? Or maybe you’re running late for a meeting and want to find the latest traffic and travel details? Let Google Assistant assist you! Our new wireless speaker, the LF-S50G, combines Sony's high quality sound - from a 360° speaker system - with help from your Google Assistant.
Manage everyday tasks Set a calendar event. Set an alarm. Check on how your favourite team is playing. Check traffic. And take care of your life without ever touching a button. |
Enjoy 360° high quality sound Hear the same great sound from anywhere in the room. And feel more from your music, thanks to a two-way facing speaker, two-stage diffuser, and bass reflex duct. |
Get answers Looking for recipes, unit conversions or nutritional information? Just start with 'Ok Google' to talk to your Assistant. Don’t forget the awesome jokes she can tell. It’s a blast. |
Listen via BLUETOOTH® technology Built-in Bluetooth® technology lets you listen to audio from a range of devices. For even easier connection, One-touch NFC makes pairing compatible devices as easy as a tap. |
Touch-free gesture control You can control the volume, pause, or play audio without being vocal. Just wave your hand over the top – no contact required. |
Auto volume control Automated volume control adapts to noise in the room so you can always listen at a comfortable level. |
Splashproof Your speaker can handle a little water, thanks to an IPX3-rated splashproof design. You can even take the cover off and rinse it under the tap. |
Clock display With an LED clock display, you never need to ask Google for the time. You can dim or turn it off to minimise electric light in your room. |
We hope you enjoy our new, stylish speaker!
By the way, what do you ask your Google Assistant help with? Share your suggestions in the comments section below.
