Sony FDR-AX53 - Add Special Lenses
LuckyMatina
Explorer
Hello,
I want to learn what i need exactly to add some special lenses and lens hood on my Sony FDR-AX53. I have never added lenses before on any of my videocameras. I will order very soon them, but i need your help. I will need any ring? I have seen some videos with glue, but i do not want to do anything like this on my videocamera. What i must see before i order (for example mm lenses)? I will appreciate any suggestions.
Thank you,
Matina
8 REPLIES 8
Jonnie1266
Contributor
Hi,
As Marino has kindly referenced, this with prices! Not sure where the Hood is though :thinking:
https://www.sony.co.uk/electronics/camcorders/t/accessories/others?accessoriesfor=FDR-AX53
Regards,
If it ain't broke don't fix it
Sorry but I don't understand, fault of my english, Hood like this?:
Manolo
Jonnie1266
Contributor
No, not your fault.
Just unable to find the lens hood on accessories, I think your picture is of lens cap ?
Regards
LuckyMatina
Explorer
Thank you for reply. I want like this you have above and also i want another one like this i found now.
I'm sorry but I don't think that there are Hood or Lens cap for FDR-AX53, nothing in European and Japanese market.
Manolo
Jonnie1266
Contributor
Hi,
I have to agree with Marino, there does not appear to be a lens hood available. I am also sorry :slight_frown:
Regards
LuckyMatina
Explorer
Thank you all for the replies and the suggestions!
Because i did not know where to search about lenses, lens cap and lens hood, i looked on ebay.
I selected the option price and shipping: lowest first.
I saw for example this: http://www.ebay.com/itm/F57-Lens-Hood-Lens-Cap-UV-Filter-55mm-for-Digital-Camera-Camcorder-Lenses-/3...
But i think that these did not fit exactly to my videocamera or maybe are in bad quality.
