Hello, I have an old model handycam - dcr-trv-265e not used for aprox 3 years. last week i tried to record something an i see only some lines on the display. On some forums is stated that is a problem with the ccd.
It is possible to repair this old model? Thanks in advance!
Hi bubulache, welcome to the Sony Forums
It may well be worth checking over to see if a repair is possible, although most repair centres will charge you a no-refundable deposit to assess the fault and estimate repair costs.
You could try the Sony customer support desk for an idea as to parts availability, or go ahead and register a repair, using the information given in this 'sticky' post:
https://www.sony.co.uk/discussions/message/651957#651957
Hope it works out for you
Mick
