What does the error code E:91:01 indicate on my Handycam PJ30VE?
Solved! Go to Solution.
Hi isakmenes, welcome to the Sony Forums
That error normally relates to the flashlight function. It can sometimes be dealt with by resetting the camera, instructions for which should be in your user manual.
Using a pointed tool such as a ballpoint pen, press the small reset button on the side of the camera for 2 seconds.
Hopefully that will clear the error message; if not, you may have to look at a repair. Let us know how you get on.
Cheers
Mick
Cheers
Mick
