Abbrechen
Stattdessen suchen nach
Meintest du:
TTL godox
profile.country.BE.title
dubroni
Neues Mitglied
TTL godox
hello , i have bought the transmetter / recepter HAHNEL for sony , but i realize that it doesn't work with the flash (godox v1) in TTL mode , i must use the HAHNEL only with the flash on Manual mode . is there a cable for sony that allow to use the flash at 1 meter of the body , in TTL mode   (not manual ) , thanks
1 ANTWORT 1
HannahEd01
Hey dubroni, what's the model number of your Sony?
