Unfortunately System UI Has Stopped
Chintu1
Visitor
Hi Support team,
My mobile not working properly.  Everytime I'm encountering Unfortunately System UI has Stopped popup. I'm facing this problem since 15 days. I need a solution to this issue.
Kindly consider my request.
1 REPLY 1
Garyloomys5
Visitor
Hola: tengo el mismo problema en mi C5 Dual, hau algúna forma de arreglarlo?
Gracias.
Hi, I have the same problem on my Dual C5, is there any way to fix it?
Thank you.
gt
