XG9505 with Android 9 and Apple homekit.
Hi
When I try to connect the Tv to Apple homekit (just updatet to Android 9.0), it comes back with an error “connection problem” and then the homekit on the TV thinks it is connectet, but it is not show on the Apple device.
The only way to reset or disconnect the homekit on the Tv is to reset factory setting.
Anyone with a solution
Br.
1 REPLY 1
Mick_D
Hi @CaptainWot, welcome to the community.
This Support article is quite recent and outlines the correct setup for Apple Homeplay on your TV.
Let us know if that works out.
Cheers
Mick
