volume level is disappeared on TV (55xe90) when str-dn1080 is connected
kouros.moabber
Explorer
Hi,
when I have connected STR-dn1080 to my TV, the volume level on TV is not shown up any more. I have changed setting of sound bar by this help in sony website but volume level has completely been diappeared even when I have changed it to both on/off and restarted both dn1080 and TV.
"Tuning on/off the display for the volume level or sound field (Auto Display)
This function allows you to turn the information display which appears on the TV screen on or off when the volume level or sound field, etc. of the receiver is changed.
  1. Select [Setup] - [System Settings] from the home menu.
  2. Select [Auto Display].
  3. Select [On] or [Off]."
Has anybody had similar issue? how to fix it?
Kind Regards,
Kooros
Tags (3)
10 REPLIES 10
HannahEd01
Hi, have you tried resetting the amp? It might be something changed within the settings. You can find the instructions here: https://helpguide.sony.net/ha/strdn108/v1/en/contents/TP0001224882.html?search=reset.
