Using Bravia 43xe8005 with external amp?
SOLVED
maayres43
Explorer
Does anyone have a solution that allows me to connect my new TV to my hifi amp without disconnecting the internal speakers?
The amp can only take phono input but I do have a DAC that would take a coaxial digital feed however hdmi is not an option.
Currently I am using the headphone jack that's inside the phono/digital socket and that works but the TV shuts down its internal speakers which mean something I have to have the amp turned on at all times.
My previous Bravia TV had phono outputs that allowed me to use the TV speakers and/or the amp as I chose and I'd really like to replicate that.
thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Caermead
Member
2 REPLIES 2
Caermead
Member
Hi, read this :-
https://community.sony.co.uk/t5/android-tv/headphones-and-sharing-tv-sound/m-p/2333255#M19363
It's the same for amp or headphones.
Regards
maayres43
Explorer
Yep, that's it.
thanks
