Hi I have a problem that I can't find the answer to anywhere. I bought a KD-43XH8596 TV. This is a time recording program. I have a Seagate HDD 500 GB drive connected to the TV. When the TV is running and I give an instant speech, the program will be loaded even if I turn off the TV. But time recording doesn't work for me. I turn on the Guide, select the program → recording timer → set the timer. Then I turn off the TV to standby on the controller, but the program is not recorded there. There is only the name of the program and 00h00min. Thank you for all the opinions, I don't know what to do anymore and no answers in the help Thanks Petrs73
Hi
Does the LED at the bottom of the TV light up in solid Red/Ember when you put it to standby after setting a timed recording?
Is the TV up to date: https://www.sony.co.uk/electronics/support/lcd-tvs-android-xh85xx_x85xxh_xh91xx-series/kd-43xh8596/d... ?
Win_88
Ahoj
Děkuji za odpovědˇ. Firmware mám aktuální v 6.4960.Když je TV nastavena a v pohotovostním stavu, tak dole na spodní liště se rozsvítí LED spíš něco mezi žlutou/oranžovou. Když to začne nahrávat tak to svítí fialově asi 10s a pak se to vypne.
Petr73
