Soundbar Issues with KD-43X75WL
DAFFY1981
Explorer
Hi Guys, i hope you can help. I've just bought the KD-43X75WL this Saturday and i love the TV but i have an issue with my Soundbar. When turning up the Volume on the soundbar using the Sony remote via eARC and ARC it turns up fine but when i turn it down it goes down a few numbers and then it stops and unable to go down further, but it will go back up. I've tried a different HDMI cable and still the same. I'm hoping its just a compatibility issue and nothing wrong with the TV or Soundbar. Does anybody have any ideas please.. Thanks in advance...
5 REPLIES 5
LightFoot
Specialist
Hi @DAFFY1981   What happens if you disable eARC and just use ARC?
DAFFY1981
Explorer
Hi LightFoot, thanks for the reply. I get the same issue using ARC.
MaggieGreene
Hey @DAFFY1981, what is the model name of your sound bar? You can use this link to help you locate the model name: https://www.sony.co.uk/electronics/support/articles/00248604
Make sure that the Bravia Sync feature is enabled by following the steps here: https://helpguide.sony.net/tv/kaep1/v1/en/04-07_03.html
DAFFY1981
Explorer
Hi, My Soundbar is a
Samsung HW-Q700B.. Thanks for the reply...
TheGOAT
Hi @DAFFY1981,
Well, you need to troubleshoot your TV first to make sure it' not causing the issue, you can follow these steps:
- Disconnect all the external devices from the TV.
- Unplug the TV from the mains for 2 minutes.
- Make sure that the TV is running the latest software update: https://www.sony.co.uk/electronics/support/lcd-tvs-android-x75wl-series/kd-43x75wl/software/0029471...
As a last resort you can Factory Reset the TV: https://helpguide.sony.net/tv/kaep1/v1/en/08-01_03.html?hl=reset
