Sound bar HT-SF200
Greenveg
Explorer
Sound bar HT-SF200
My Sound bar has become erratic. Sometimes it connects to  my  Panasonic smart tv, and sometimes it  will not connect. I am using a HDMI  cable.
6 REPLIES 6
royabrown2
Hero
@Greenveg
https://www.sony.com/electronics/support/res/manuals/4727/9327b9e0e863d91c9226e5bff1163675/47274142M...
If the troubleshooting in your manual here does not help, try the reset as on page 33.
My favourite bedtime reading is a Sony product manual…
SatoruGojo
@Greenveg , can you test it with another HDMI cable.
Greenveg
Explorer
You  could be  right. Sometimes when it will not connect I unplug the HDMI cable from the ARC port,  plug it in again and  it connects. Should I  be  looking for a particular HDMI cable.
royabrown2
Hero
@Greenveg
High Speed with Ethernet, as a minimum. A Premium cable is theoretically better, but isn’t strictly needed in your setup.
One of the Amazon ones is perfectly acceptable; don’t pay extra just to get one slathered in snake oil.
Greenveg
Explorer
I purchased a HDMI cable, but the problem remains.
Greenveg
Explorer
I have reset the  sound bar, and it seems OK now.
