Sony TV KD49X8005CBU and Touchpad remote RMFTX100
Costeta
Member
Hi,
I have a Sony KD49X8005CBU 4K TV. Does anyone know if it is compatible with the Sony Touchpad remote RMFTX100. I can't find any reference on the Sony web site.
Thank you.
5 REPLIES 5
Anonymous
Not applicable
Hi there
Yes, its compatible.  See link below, under Compatibility > Optional Accessories
http://www.sony.co.uk/support/en/content/cnt-specs/KD-49X8005C/list
Cheers
Costeta
Member
Great.
I don't suppose there is any difference between the remote RMFTX100E in the specs and RMFTX100 on the John Lewis web site?
Costeta
Member
Thank you once again
Anonymous
Not applicable
Hi there
Your Welcome :slight_smile:
I dont think there is a difference.  Last time i looked into this, there are 2 versions, an E and a U.  Europe and USA.  I think some companies miss this off the model number.  Either way, it the same and will work.
Cheers
Costeta
Member
Hi,
I got my RMFTX100 remote and it works just great. Thank you.
