jrpjrp
Explorer
Sony KE48A9
I need to know the distance between the bottom screw holes in the back of the TV in to which the wall bracket is attached to the actual bottom of the TV on the 48" OLED??
2 ACCEPTED SOLUTIONS
Accepted Solutions
IamNic
Hello @jrpjrp,
according to the spec-sheet on the Sony website it is 30x30 centimetres VESA.
- Nic
Joe_Dohn
Specialist
Have you tried using a different cable or a different HDMI port? Seems like the Sky box is the culprit if it's the only one causing the issue.
8 REPLIES 8
IamNic
Hello @jrpjrp,
- Nic
Joe_Dohn
Specialist
And here's the link to the spec sheet.
IamNic
Hi @Joe_Dohn,
thanks for providing the link.
- Nic
Joe_Dohn
Specialist
My pleasure ^^
jrpjrp
Explorer
Hi Joe My KE48A9 is proudly installed with a wall bracket. Could I ask another question. I have a HDMI lead connecting my SkyQ box. When I switch on the TV and my SkyQ box the TV shows the Sky screen then clicks off to a blank screen
repeatedly for 3 or 4 times before showing to view. Is this normal?? Is there a preferred HDMI input (I also have a DVD player connected but this is seldom used)
Joe_Dohn
Specialist
Glad to hear that!
As for the other question, does it click off using the DVD player as well or is it only the Sky box?
- JD
jrpjrp
Explorer
Hi Joe
Just the SkyQ box which is connected to HDMI 4.
DVD fine
Regards
John
Joe_Dohn
Specialist
