Hi, folks.
Hope someone can please help.
Can't get the WiFi to work on my TV as of last night. I try and turn the WiFi on in settings, but it keeps switching back to the off position and also doesn't detect any WiFi (also when I do a full reset). Is there anything I can do, or is this most likely a hardware failure?
Thanks
Hi,
Have you tried if disconnecting the TV from power for some minutes does solve the issue?
Cheers
Peter
