Kd43xf8577su
SOLVED
Vwtroc4228
Explorer
Kd43xf8577su
Why ďoes this TV not turn off after a certain time for safety and save electric
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there,
Welcome to the community. :slight_smile:
Please follow the steps outlined here.
Let us know how you get on.
Best wishes,
M
4 REPLIES 4
Anonymous
Not applicable
Hi there,
Best wishes,
M
Vwtroc4228
Explorer
Some how things have got mixed up,my question was does this TV turn off on its own if left switched on and gone out or gone on holiday,ie my previous LG used to turn off if you had not used remote for 4 hours,sorry 're mix up but was not down to me Michael
Sent from Samsung tablet.
Win_88
Specialist
Hi Vwtroc4228,
If you go to Settings - Power - Eco - Idle TV Standby you will be able to choose how long should the TV stay On without any interaction before turning itself Off. The options are 1, 2, 4 or 24 hours.
Win_88
Vwtroc4228
Explorer
Hi  Win  -88,Thank you very much for your help VW t roc
