- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello guys
Few days back I bought a new KD-65x9000f & having a kind of peculiar issue with the same. My audio system ONKYO S3800 is connected to HDMI Port 3, which has ARC & I have number of devices (One PC running Windows 10, A Satellite receiver, Amazon FireTv stick) connected to it. The HDMI out on the audio device is equipped with ARC & supports 4K60p.
My issues are listed like below:
As soon as I start the TV, the Mode on my Audio System lcd panel changes to TV. I switch the audio system input to CBL/SAT or BD/DVD using the remote, the feeds are displayed & I can use the TV remote to control the audio system volume. The issues start when I switch off the TV. The audio stream from CBL/SAT or BD/DVD continue to play, forcing me to switch off the audio system.
I did a factory reset on the TV & out of 10 times, 6-7 times switching off the TV changes the mode on audio system to TV and the audio stream is automatically cut off. Other 3-4 times, I must switch on the TV once again and switch off to stop the audio from playing.
Currently the android version is 7 on my TV & my audio system is loaded with latest firmware.
The ONLY one thing I haven't done yet is resetting the audio device. Should I do that? or this is exepcted behavior of AndroidTV?
Please suggest.
thanks
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Actually I was drafting another reply while your last post came. Today morning I reset the ONKYO device & realized that the behavior remains as listed below.
Turn on the TV
The mode on the AVR changes to "Tv"
Manually switch to CBL/SAT or BD/DVD, Tv starts receiving the video feed and AVR receives the audio feed through a fast HDMI cable with ARC enabled
Turn off the TV, the AVR immediately changes the mode to "Tv" and the audio feed is cut off
Turn on the TV, the mode on AVR changes to "Tv"
Manually changed the AVR mode to BD/DVD or CBL/SAT
Turn off the TV, the mode on the AVR remains whichever mode that was manually selected & audio continues to play
After reading your last post, I am slowly indulging the idea that CEC doesn't always work with ONKYO & preparing myself to live with it. I had to decide to live with this minor annoyance after reading about HDMI vs Optical at CNET.
Thank you very much once again for all your kind inputs. As I've said earlier, I hardly knew these many details until date & glad that I learned few new things just because of this thread.
regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you in turn for your kind words - I am glad I am able to be helpful
I’m starting with your last post, as there is a misapprehension here I need to correct before going back to the post before it. You said:-
Manually switch to CBL/SAT or BD/DVD, TV starts receiving the video feed and AVR receives the audio feed through a fast HDMI cable with ARC enabled
Which would be true if the CBL/SAT and BD/DVD were plugged directly into the TV - as indeed has been suggested here by @Win_88 as an alternative way to connect things (which I will come back to in my next post).
But as I understand it, the CBL/SAT and BD/DVD are plugged into the AVR (the Onkyo), not the TV, so this should be:-
Manually switch to CBL/SAT or BD/DVD, AVR starts receiving the video and audio feed from that device through a fast HDMI cable with no ARC needed or set, and the AVR passes the video to the TV via the HDMI cable to the TV, again with no ARC needed for this.
The rest of what you wrote there is fine.
In the above, all the signals are going one way e.g. CBL/SAT -> AVR -> TV so ARC (Audio Return Channel) doesn’t come into it.
But let’s imagine the TV is tuned to something, or you have a device plugged into that and not the AVR, and you want the sound to come from the AVR, not the TV.
So we have the HDMI cable to the TV going AVR -> TV as above. But with ARC, there is one wire in the HDMI cable that goes the other way, from the TV to the AVR, with audio only.
And your AVR knows that when you select TV, you want the AVR not to send video up the HDMI cable to the TV, but just to listen to that one ARC wire with audio coming back from the TV, and to play you that audio.
This post is to explain what ARC does, which is normally quite separate from what CEC does, though your AVR seems to entangle the two, making it harder to understand what’s doing what.
I’ll come back to CEC in my next post, replying to your post before this one; but hopefully you can see why I had to cover this one first.
My favourite bedtime reading is a Sony product manual…
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
As I already mentioned, I hardly got much exposure to audio systems. I have very small sitting area & the ONKYO did good until I decided to change the TV.
Trying to find a solution to my NOT really an actual issue has brought me to so much knowledge, like what is ARC in clear layman terms etc. Thank you very much.
Rest about the connection, you are 101% right. All my external devices are connected to AVR and one HDMI goes "up" to the TV
regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@rajthampi (replying to the post about what ‘player’ means there.)
Truth to tell, I don’t know quite what your manual means.
If you turn off CEC (BraviaSync) on the TV, then your TV remote will likely no longer control the AVR, and you will have to use its own remote.
From what you have told us, the best option would be just to stop the ARC, either by using a non-ARC HDMI input to connect the AVR, or by turning off ARC in the menus of the AVR (p31 in your AVR manual).
Its not at all clear from the AVR manual what its behaviour with regard to CEC is; whether it is always on, or normally off but it turns on when you use ARC, or what. I couldn’t find any setting on the AVR that lets you control CEC, though, so I guess it does what it does.
Now, where to connect your devices - to the AVR, or the TV? I would leave them where they are; it’s what you are used to, and as the AVR does seem to be up to the minute, it will push the video to the TV without any loss compared to the video you get by directly connecting your devices to the TV, and you may find it treats the audio better than what you would get down the ARC wire from the TV.
So, bottom line; leave the devices connected to the AVR, move the HDMI cable from the ARC HDMI port on the TV to a non-ARC HDMI port (these ports can have different specs on other Sony TVs, so if that is the case here, choose the one with the highest spec), and you should find it will work just like the KLV-40 did.
You won’t get sound back from the TV to the AVR, either from the TV tuner or from any other device plugged directly into the TV, but as far as I can tell, you don’t use these options, so it doesn’t matter.
If it does matter though, go back to using the ARC HDMI, and you will have to get used to the slightly different way the AVR works when you have ARC.
Or if the non-ARC doesn’t work like the KLV-40 did, when you try it, again, go back to the ARC HDMI and get used to how things work with it on.
The setup with ARC will be useful in the future if you run out of HDMI inputs on the ARC [Edit: AVR], and have to plug any further device(s) into the TV.
You will have to try these CEC versus non-CEC and ARC versus non-ARC options for yourself, as the AVR manual doesn’t give enough detail for me to predict exactly how these will behave.
But one of these options may work just like the KLV-40 did for you; and if not, you know you will have to get used to the new rules
Nothing here that would make me want to change what seems like a top-notch AVR because of one small oddity though
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello @royabrown2
Well, I tried with ARC disabled on the AVR & as soon as the ARC disabled:
No TV remote controller cannot be used for AVR volume
The most interesting part of the ordeal is, once ARC is disabled, if I start youtube or netflix, the TV speakers plays the audio and my AVR continues to play the audio from current selected device.
So finally I decided to enable ARC & continue with my minor discomforts as the viewing & listening experiences are far far different than my previous setup.
Thank you for your patience & the time you spent on behalf of me. Really appreciate it.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Glad we got to a resolution!
Yes, if you use Netflix or YouTube on this new TV, you do, as you have found, need ARC to get the audio to the Onkyo.
I still don’t know how the audio on the previous TV would get to the Onkyo if you played apps like these on it, if it didn’t have ARC and you only had the one HDMI cable linking them; but that is a problem for the past, not the present
Anyway, we now know you have things set up the best they can be, so I hope you and your family can soon get used to the new way things work!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @royabrown2
My other TV, which was non-smart ONLY gave me the video & audio was always handled by the ONKYO. So there are hardly any confusions as NO devices were straight away plugged to the TV, other than the AVR. I used either Amazon FireStick or my PC for youtube & netflix before the new Tv & yes, things were as I listed in my previous updates
I think it's going to take me sometime to really understand how the entire setup sync together & may comeup with something better.
Thanks and regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ah, that explains everything.
You never played anything on the old TV, except from the AVR, so there never was a need for audio to go from the TV to the AVR, nor for the TV speakers to be used - maybe they never played any audio (or maybe you had them always muted) so sound only ever came from the AVR.
But now, with all the goodies on the Smart TV, you are wanting to play things from the TV itself, so to get the sound to the AVR and mute the TV speakers, you do need the ARC on, as it is the only thing that does this automatically.
So do try to understand how it all syncs - I recommend getting a big sheet of paper, drawing a box for each device, and then separate arrows for video and audio (even if they are actually in the one cable) showing what signal is going where. Arrows in pencil, as there might be a bit of rubbing out and redrawing
And then thinking about what might be better on a copy of the diagram, drawing the arrows accordingly, and then trying it for real.
But don’t be surprised if you conclude that how it is now is the best it can be
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
haha not entirely true! I am 45, managing a midsize IT infrastructure & was doing database development from early 20s & a techblogger. My "Wife" INSISTS to believe that, I am born to figure out all issues related to all the electronics junk at home & we had loads of debates before she decided to GIFT me this new TV (the other one is rock solid with not a single pixellation or other technical issues after almost 8 years). As soon as she found me fiddling with multiple remotes & my frustrations, started giving me those "I've told you" looks (haha)
Well @royabrown2 , there were times when my wife or kids forget to turn on the AVR & my KLV-40 used to switch the speakers to TV & played the CBL/SAT or BD/DVD (ONKYO does let the HDMI signal passthrough it regardless whether it is switched on or not). There were NO muting on the TV ever done, the TV is intelligent enough to switch between TV speakers and AVR (Which turned on) & yes, there were few occassions, I had to go to settings on the TV to change the speaker setup to Audio system. That I believe, happens even with the software I develop for a living ;). Occassional bugs or unforeseen scenarios.
Now the entire atmo has changed. Wife and kids should get multiple remotes, fiddle with them until they "SEE" and hear things. As you said earlier, yes, it is the new way and I am sure my smart girls (Wife and 2 daughters) will get used to it.
You are very kind @royabrown2 . I know this is a technical discussion thread, however, want to relate something. Few of my blog threads are pages long with 10s of images & many occassions I spend hours to compile an article. My wife considers it as a thankless job and today I let her sit with me and go through our conversation. After few minutes she said "So, you are NOT the only one ..." I think she wanted to say "crazy dude out there". Haha, well, most of the times thare are few chaps like YOU out there to guide few guys like us. Stay blessed friend, I really really appreicate your time.
regards,
- « Previous
- 1
- 2
- Next »
