KD-55XD8599
Jamalata
New
KD-55XD8599
Hi there, my tv remote control just stop for no reason, batteries changed still won't control tv, the worst bit is that I can't even use the manual control on the back of the tv to get to menu/setting. Also tv now changes from HDMI input to some balloons....this is weird. Any solution pls. ?
1 REPLY 1
EdwinaU
Hi Jamalata,
Welcome to the community.
It's worth checking your TV help guide and manuals here to make sure everything's updated. If that fails, we'd suggest you contact support about these issues. You can reach them here.
Cheers,
EdwinaU
