KD-49X8005C - Bluetooth Headest Compatibility
SOLVED
.M4rc0
Explorer
Hello Everybody.
Can someone tell me if the KD-49X8005C Android TV supports some bluetooth headset devices?
Thanks for any feedback.
Marco
1 ACCEPTED SOLUTION
Accepted Solutions
jumpsuit
Hi @.M4rc0 and welcome to the Community :slight_smile:
I believe the only headphones that will work with this model tv aren't bluetooth.
They are TV dedicated RF headphones  which have a seperate send/receiver
Have a look at the MDRRF811 or MDRRF895 headphones.
Hope this helps
2 REPLIES 2
jumpsuit
Hope this helps
.M4rc0
Explorer
Thanks! :slight_smile:
