Internet connection issues
drewatthemovies
Explorer
Hello there, anyone else having issues with internet connection on their Sony TV,?. mine comes and goes and has to be manually re-connected. VERY annoying. HELP!?.My TV.is an older model, KD-55X8509C.
Tags (1)
1 REPLY 1
Anonymous
Not applicable
Hey there,
The road for a stable connection will always be a LAN cable, but you might wanna check the software for the TV and update it.
Clear the TV cache and data and leave it off for a bit and test it once more.
Hope it helps
