Game Mode Audio Sync Issue
profile.country.IE.title
Shnakey
Explorer
Hi everyone,
I have a frustrating issue with my x950h/xh950. When the image from my PC or Xbox is outputting at 1080p, there is a half a second audio delay on the TV's speakers. It can be rectified by changing resolutions back and forth on the PC. On the Xbox the problem seems to be intermittent.
It's driving me crazy. It only seems to appear on the Game Mode which leads me to believe it's to do with the 120hz refresh rate. I've tried disabling every picture and audio setting possible with no luck. I've also fiddled with the Xbox and PC settings.
Any advice on this would be much appreciated,
Thanks 👍
5 REPLIES 5
Shnakey
Explorer
Also to clarify, I've updated the software to the latest version.
Win_88
Specialist
Hi @Shnakey
I wonder if you notice any improvement once you unplug the TV for a few minutes?
Win_88
Shnakey
Explorer
I've tried that without success. The issue reappears again. I've read a lot of other threads regarding sound sync issues with HDMI devices. Maybe this issue is linked?
Soulfly-Tribe
Explorer
Hi,
I have the same issue, when I change to Game mode picture.
Could you fix it ??
its happens sometime when I change from other mode to game mode. Other times work fine.
The delay it like a 0.3 sec or less.
Thaaanks !!
HannahEd01
Hey, which model do you have? Did you try the power off thing? Also, what's the source of the sound? The TV? Or a sound system?
