Ethernet keeps saying not connected every time I go to home screen go to details and it is connected
Hi there,
Which product are you using?
Best wishes,
M
I'm also having this problem, my product is a 65A1 oled TV.
Try this...
After a software update, some apps such as Prime Video™, Netflix® , and YouTube™ streaming services may not respond while others operate normally on your Android TV™. This occurs because the TV clock settings are not correct. To resolve the issue, set the TV clock to the correct network time.
