I am trying to connect my bluetooth AKG Y45BT headphones to my sony KDL 32 EX403 TV.
I have purchased a bluetooth audio transmitter TaoTronics TT BA-07 and put that into the headphones jack of the TV.
I have put the transmitter in pairing mode and seems to pair OK with my headphones (at least there is the pairing beep I normally hear!)
However, no sound is coming out via the headphones, and it is still coming out from the TV speakers.
I feel there must be some setting I need to change on the TV itself so that it 'sees' the transmitter and/or headphones, but I don't know what it is.
Can anyone help?!
Thank you
Hi,
Usually the sound should switch to the headphones when you insert a 3.5mm plug into the headphone out jack.
Can you please check it's fully plugged in?
Cheers
Peter
