Anyone know if I can get Bluetooth headphones for this TV
SONY - BRAVIA KD49XG8096BU 49" Smart 4K Ultra HD HDR LED TV with Google Assistant
Product sold as the bundle D0000001
Any generic bluetooth headphones should work !
Unfortunately no. This entry level tv model does not have the a2dp bluetooth profile to connect audio devices.
Yes it does I have the same model and use my bluetooth headphones with it
Download the app called Bluetooth Scanner ,you will be able add your headphones via this app!
