- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
January 2016
January 2016
I usually power off at the plug socket each time I finish using my Tv, For my newly purchased Android Sony TV I can't work out how to power on and go straight to viewing my Sky HD, after the boot sequence to goes to the Home menu.
How do I set the power on preference to be HDMI 1 which is my Sky box? I was able to do this on my previous Panasonic.
Thanks
Solved! Go to Solution.
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2016
February 2016
Hi there
If you enable 'Control for HDMI' on the Sky HD box and enable Auto TV on in the Bravia Sync settings. Then all you have to do is switch the Sky box on, and the TV will switch itself on and change to the correct HDMI input.
Cheers
2 REPLIES 2
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2016
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
March 2016
March 2016
Cheers now working thanks.
