65XE9305 PC - 60hz, not 100hz
gpt1985
New
Hi,
I have the 65XE9305 and have recently upgraded my PC system to the latest 3070 graphics card. The OC system detects the TV as the following
I would like to make sure I am getting the most from this TV when I am using my PC. At the moment I have an older HDMI cable connected to the HDMI 1 port. I do have a newer cable that I can try but was hoping for some advice on how to get the most out of my TV in this scenario. I play a lot through my TV including games which I will likely be running at 1440p. I immediately noticed that the TV is running at 60hz and not the 100hz listed as motion flow.
Can anyone offer any advice for improvement.
Thanks
1 REPLY 1
HannahEd01
Hi,
Looking at the TV specs, it can only transmit up to 60hz from the HDMI output: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-65xe9305/speci...
So mainly this is within specs. Try the new cable to get a smoother picture anyway.
