Why am I not able to record in 24 Mbps?
ackesonn
New
I bought the Sony ILCE-5100 and the sony sdxc class 10 uhs-1 u/3 memory card
( https://www.amazon.com/Sony-Memory-SF64UX2-TQ-VERSION/dp/B00X140BEW/ref=sr_1_1?ie=UTF8&qid=147785066... )
Every time i try to change the record settings to 50i 24m(fx) there is a note that says ¨cannot record to DVD disc at 24M (FX). Save on a Blu-ray disc.
What should I do? Any fast answer is appreciated, traveling to Thailand in a couple days.
THANKS!
3 REPLIES 3
Hi,
maybe?:
24p 24M(FX)*
* 1080 60i (NTSC) compatible device
Your camera is set in PAL?
Manolo
ackesonn
New
Hi!
It says the same thing in both NTSC and PAL !?
Thanks,
Aleksi
I'm so sorry, maybe I was tired...
I've confused 24 Mbps with 24p... So... I've wrote an uncorrect answer...
That message is only an advise, in 50i 24M you can't write a DVD Disc but you have to write a Blu-ray Disc or AVCHD Disc...
  • Movies recorded with the [60p 28M(PS)]/[50p 28M(PS)]/[60i 24M(FX)]/[50i 24M(FX)]/ [24p 24M(FX)] /[25p 24M(FX)] setting in [Record Setting] are converted by PlayMemories Home in order to create an AVCHD recording disc. This conversion can take a long time. Also, you cannot create a disc in the original image quality. If you want to keep the original image quality, store your movies on a Blu-ray Disc.
    Manolo
