Video edit systems
gbcegae
Explorer
Video edit systems
Which video editing systems totally support a Sony Alpha 7R 5?
1 REPLY 1
Anonymous
Not applicable
There's a few Sony supported software which should work with it like Imaging edge, Master cut, and Creators' Cloud Web to gather all the content at one place, so you can check them if you're interested: http://bit.ly/3Yd7lxi.
