Does anyone have any experience using bulb flash with tha A7 series? I am told that there might be voltage/current issues, but I don't know where to look or what I am looking for! I generally use an old Leica/Leitz flash from the '40s that I converted to hot shoe years ago. Of course the cable is still used on (Minolta film) cameras with the x/fp switch😜. Any help would be appreciated, though I am not looking for a remote/wireless triggered solution...
Thanks, Peter
Hi Peter,
Welcome to the Sony Community.
I will look into this and will update the thread when I've an answer.
Best wishes,
Sean Mc
Cheers, Sean
I don't want to blow the electronics before I get to know the beast
Peter
Hi Chwilfrydig,
I've tried to look this up on the Sony website, I couldn't find specific information regarding this. But I don't think that the connection will be fully supported in this case as you're using an old flash model. I also found the compatible flashes with your camera here: https://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=gb&lang=en&mdl=ILCE...
Cheers,
Vanilla_
So far I decided to try wireless triggering with standard flash radio transmitters, however they appear not to 'short out' the contact, which is required by my flashes. Any ideas anyone? Is there a remote trigger that will work with my ancient bulb-flash?
All answers appreciated!
Peter
