Sony alpha7C clunk when rotating camera
patnovel
New
Just unboxing my new camera….a very audible clunk/thud from inside camera body when I rotate from landscape to portrait?
Does your alpha (7c) do this?
Just want to double check….
4 REPLIES 4
patnovel
New
Feels like the inside is moving when I rotate it…a lot more than my RX100 so wondering if this is the norm for alpha cameras?
Joe_Dohn
Specialist
I haven't seen/heard of such an issue, but I'd just take this right back to the store and have them check it out/compare it to another one just to be safe.
cerberus1846
Explorer
it's perfectly normal - it's the IBIS system.. if you power the camera on with a lens and rotate it.. it won't make a noise..
Notend
Explorer
I have been using this model for a long time.
