NP-FW50 at 20% of price?
SOLVED
profile.country.RO.title
Vandraattila
Explorer
I was looking for a second battery for my Sony Alpha 7. On the Sony.ro site its price is 322 Ron (about 70 Euro) I found it in az online market at 67 ron (20% of its price : https://www.photosetup.ro/acumulatori-si-incarcatoare/compatibili-sony/digital-power-np-fw50-acumula...)
I am interested of your opimion may I trust in it?
If not what is the problem with them?
Anticipated thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Almou_10
Specialist
Hi Vandraattila,
I wouldn't be so sure about that but I wouldn't personally recommend using any non-original spare parts.
Cheers,
Almou_10
5 REPLIES 5
Pascale_F
Hi Vandraattila,
I'll just see if i can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Almou_10
Specialist
Hi Vandraattila,
I don't think this is an original Sony battery. It says clearly on the battery that it works for Sony Np-FW50 so it wouldn't be the original Sony one.
Hope this helps.
Almou_10
Vandraattila
Explorer
@Almou_10 wrote:
Hi Vandraattila,
Hope this helps.
Almou_10
It is not, is clear. The question if may I trust in it, or not? If the single problem it is, that it has a shorter life, no problem. I was interested in eventually risks. E. g. it gives a different (uncertain) voltage, which can harm, it has a different shape, etc.
Thanks anyway.
Almou_10
Specialist
Hi Vandraattila,
Cheers,
Almou_10
Vandraattila
Explorer
@Almou_10 wrote:
Hi Vandraattila,
Cheers,
Almou_10
Thanks, Attila
