Memory cards and FULL HD
SOLUCIONADO
profile.country.bg_BG.title
Apostolll
Visitante
Memory Stick Mark 2  or Memory Stick PRO-HG Duo HX -   which one is better for Full HD recording 17MB/s in my NEX-5 ?
1 SOLUÇÃO ACEITE
Soluções aceites
profile.country.en_GB.title
Watashiwateshdes
Participante
Both work just as well as each other. So far testing them both out, I have had no differences in performance.
Transfer speeds may be limited by the camera body if using USB direct from it so you could also try a high speed USB memory card reader when transferring to PC.
Ver solução na publicação original
1 RESPOSTA 1
Watashiwateshdes
Participante
