Ligthpainting with A9
OB_Norway
New
Suggestion, In Olympus cameras you have a function called live composite. I use this part as I do light painting a lot. This means that the camera takes a base exposure, it also takes pictures until you stop, but the rest of the exposures only added light is added to nothing else (you dont need filters for this). see youtube for olympus' solution to this. It is at least a function I want in new firmware for A9
Anny one else ligthpaint?
1 REPLY 1
HannahEd01
Hey OB_Norway, good suggestion, you could contact Sony to propose the suggestion formally to be taken into consideration.
