Hi Community
I record in 25p 100M using objective SEL1635Z with Optical steady Shot on objective. SteadyShot on ILCE-7M3 is on and set to auto.
Anti-flicker recording set to On.
Problem
When panning fairly slow the video file is "flickering" / "jumping" in frames. This is happening in the raw produced .mp4 version and after rendering clips in Vegas (Sony XAVC S 3840 X 2160-25p).
Computer:
Intel(R) Core(TM) i7-7820X CPU @ 3.60GHz 3.60 GHz, 64,0 GB RAM, Windows 10 Pro
Monitor:
Display resolution: 3840 X 2160. Hz 60.000, 8 bit,
Video card:
NVIDIA GeForce GTX 1080 TI
Computer:
Monitor:
Video card:
Hello @Claussvn,
sounds to me like you selected a very short exposure time per frame.
Can you upload a sample to YouTube as 'not listed' and also include your settings.
- Nic
Hi there, I just read that the anti-flicker isn't available in Movie shooting mode.. Could you clarify all the settings used?
