noisy lcd-screen in low-light
profile.country.nl_NL.title
djowii
Bezoeker
Hi,
I just bought my Sony Nex 5N and the thing I noticed.. when in low light, the screen is very pixel'ish... it has red noise and pixels jumping all over the screen. Is this normal?
This effect can be best seen by turning the camera on and leaving the cap on, it'll be a black screen with red spots bouncing around everywhere.
When the cap is taken off and the camera is in a low light setting, this effect appears, but when taking in a bright environment its gone.
Image quality is ok by the way when a picture is made, it's just what the screen is showing while while composing the picture, that's noisy.
Message was edited by: djowii
2 ANTWOORDEN 2
djowii
Bezoeker
anyone? it's very Grainy
-Tycho-
Ontdekker
Dear djowii,
Welcome to the Dutch Sony forums. Please note that this is a
Dutch language forum and it will be easier for users to respond to you if you
post your message in Dutch. For questions in the English language please access
the English forums by clicking the language selection option at the top right of
your screen, next to the Sony logo.
Kind regards,
-Tycho-
Forum Moderator
Beste djowii,
Hartelijk welkom op de Nederlandstalige Sony forums. Aangezien dit forum speciaal bedoeld
is voor Nederlandse gebruikers, is het makkelijker voor de gebruikers om u te
helpen als u uw berichten in het Nederlands plaatst. Voor vragen in het Engels
kunt u terecht op de Engelse forums, deze zijn te bereiken door op de taal
selectie knop te klikken rechts bovenin uw scherm, naast het Sony logo.
Met vriendelijke groet,
-Tycho-
Forum Moderator​
