How do you set downloads to go straight to your SD card
Chrome>settings>downloads>download location
Hi @AZTECK, welcome to our forum!
Is it normal files you are downloading using a web browser or how are you downloading the files?
The podcast, movies, TV shows and music apps that I use all have a setting inside the apps where I can choose where the downloaded data should be stored (internal storage or SD card).
There is no general setting in the device that all downloaded data will be stored on an SD card and applications can't be stored on the SD card as this option is not available.
If you could provide some more information that would be great!
