Bluetooth calling 10000000
profile.country.DK.title
Onkel_D
New
Help..
My Xperia 5 is randomly calling 10000000 when Bluetooth connected to headunit, I can't see any pattern...
Also is media volume randomly toggling between media and phonecall volume, causing probs with listening to music thru Bluetooth...
Tried to disable all possible phone permits, but no luck...
4 REPLIES 4
Lord_viridis
Try this, found on another forum with same issue.
Go to settings.
Apps and notifications
App permissions
Phone
You'll see a list of all applications only focus on the ones that are toggled active.
Start at the top and disable the first one.
Toggle Bluetooth off and on and test to see if you get phantom call.
If you do get the phantom call re-enable calling access for that app and repeat these steps down the list.
Some services will warn you that it will break functionality. This is fine as you will most likely be re-enabling.
Once you locate the offending app remove it, leave the calling functionality disabled, and/or inform the developers of the issue. For me I still need the app but will leave calling disabled unless I need it.
Onkel_D
New
Thanks, but it didn't work..
Could it be a bug in an update?
Piscie
@Onkel_D,
Try to enable the safe mode to check if the issue is still happening or not. If not, it might be one of your apps is causing the problem
Onkel_D
New
I've tried safe mode and it doesn't do it then.
Are there any other way, or am I'm going to delete every app one at a time?
Should I restart the phone every time I've deleted an app?
