Update 65.2.A.2.179 (Xperia 10 IV) Misalignment problems
fsbarbero
Explorer
I have installed the 65.2.A.2.179 update in my Xperia 10 IV (XQ-CC54). Apparently, the installation was completed correctly without any problems.
At the moment, I have noticed an aesthetic glitch in relation to the bottom controls of the screen, which appear slightly misaligned. This misalignment is especially noticeable if you have 5 apps at the bottom, so that the central app is not aligned with the central control button. I don't know if this misalignment is related with the apps or with the control buttons.
Of course, as you can see in the screenshot, since a couple of updates ago the black gradient at the bottom has disappeared. This gradient only appears when you restart or turn on the phone, but when you open an app or the app drawer, the dark gradient disappears.
Has anyone noticed any of these issues or others?
1 REPLY 1
Anonymous
Not applicable
Hey @fsbarbero
The apps in the picture you sent showing fine for me, do you have another pic?
