Flashlight / torch not accessable
soderdaen
Explorer
Hi,
Another Problem with my Brand new Sony Xperia 10 VI.....
I cant turn on the flashlight / torch very often via the quickaccess Panel. It says that the Camera is using it already, which obviously is not true. I even close all open apps and it doesn't help. Only a restart helps but after a while then problem reappears.
Any bugfix? As far as I got the new phone there were several software issues, Apps crashing and freezing and my other posts here and all the Support says I should repair the software. It seems like Sony has no clue what they are doing and they care even less about customer satisfaction.
1 REPLY 1
SatoruGojo
@soderdaen Try to follow this article Troubleshooting made easy with these 7 Tips, make sure the software is up to date and see if that helps
